engidude
- Feb 10, 2011
- 40
This is my spreadsheet for flat slab design:
The demand and capacity moments moments seemingly have same units( all in ft.kip or ft.lb), however they are not comparable according to the program's error message.
the moment demand is Mu.str_pos is in <ft.kip> uints, while ϕMn.pos seems to be in <ft.kip> in the calculation equation per reinforcement and section geometry. however, if I output ϕMn.pos again, it is in <ft.lb>, and if I use units conversion tool try to change to <ft.kip>, it changed into "sec^/ft*ft.kip.
I highly appreciate your answer.
File attached
File attached
