SuperStress,
That helps with something that has been residing in my 'hmmm-box' for years, now. (That is the place in your brain where, when you see something that does not jive with what you think you know or understand, you think, 'hmmm' and plant it back to be dealt with in the future).
I already related the ME lab where we learned about the advantages of using friction in a tension joint situation to get much higher strength than just the shear stress of the bolt(s) alone, but as I have boarded many (way too many) airliners, and saw the rivited joints, I filed a 'hmmm' away in my 'hmmmm-box'.
So, my question is, along with the shear stresses on the rivets or Hi-loks, do they produce any tension, or if they do, is that used in the joint strength calculation?
In my world, I still see, from time to time, and when I began in the engineering world with my slide rule, I used to still see a lot of boiler drums and pressure vessels of rivited construction. I drive by an old rivited construction receiver tank at a natural gas metering station near my office every single day of the week.
While this method is no longer in use to any extent that I know of, at least, I did understand that the cooling of the red hot rivet after it was installed and peened into place, tensioned the joint at that point, and that was as good as a bolt tensioned to a particular stress by stretching.
So, it fit within the parameters of the lesson learned in the ME lab, and, other than the antiquity of it, does not go into my 'hmmm' box. (Notwithstanding the fact that caulking riveted joints was also a common maintenance practice with such vessels.)
I do make the observation that if that tank were to be replaced with a new modern welded tank, one weld seam that would barely be visible from the roadway where I pass, some 20-30 ft away, would replace a whole lot of rivets used to join the lapped ends of the current pressure vessel shell.
I guess, as part of dealing with the 'hmmm' situation in my mind, I assumed that there was some combination of factors, like the need to maintain the lapped skin joints of an aircraft tightly together that prevented the use of threaded fasteners in tension on much greater centers than the riveted joints. I also assumed that in the manufacturing process, a joint of a given length could be riveted in much more rapid fashion than with a worker twisting a wrench to tighten a bunch of screws.
Am I any where close to the mark, or do I have to repeat Aerospace 101? I appreciate your coming back to me and enlightening me on a topic that has been a curosity for me for a while.
You must remember, that in my paradigm, I deal with Boilers and Turbines that operate at just under 4000 PSIG, and as you can imagine, in the case of the turbine, for example, the bolts that clamp the two turbine shell halfs together are massive. Sometimes several inches in diameter, 4-6-8", and are tensioned to discrete stretch values, accomplished by heating (much like the rivet situation) or torqueing (sp?). In the old days, we knew the thread pitch, and calculated how far the nut had to twist once it had begun to tension to get the amount of stretch needed. Today, they use fanciful hydraulic torque wrenches. We used to use slugging wrenches, one guy operating the sledge hammer, and another one standing on the wrench to keep it from jumping off as it was struck with the sledge hammer. We have come a long way baby!!!
Many a time, in the old days, I had the task of mounting a dial indicator on a 6" bolt (stud) and measure the elongation to verify the tensioning, whatever the method used.
Leaving such a job, and getting aboard an aircraft with riveted construction really stirred up the 'hmmm-box' I have found this discourse very interesting.
I guess I am going to have to get the 'star' button hot to show my gratitude.
I still would not walk under the aforementioned engine being supported by one 3/8" bolt of any grade. But, that is just me.
rmw
