Hey all. HVAC is not my area. I'm trying to find a way to air condition a shop space. I bought a portable A/C unit. I need something bigger, but that's not the point. With the portable, the thing exhausts a ton of air. It has a hose and you send the hot exhaust outside. So, my issue is that if my space is losing a ton of air, something has to0 come in to replace it. If the air outside is 100F, it doesn't seem like I'm doing a whole lot.
Split systems have solved. My question is do window units and through wall (hotel type) have net air loss from the space? I'm getting quotes on split systems, but if a through wall doesn't net loss a bunch of air, I might consider that route. Thanks
