Naidooru
Petroleum
- Jan 14, 2015
- 9
Hi all,
Please advise on the meaning of open to atmosphere.
Scenario: If i have built a drain line with two spools. One is a flanged on both ends and the other flanged on one side with an open end on the other that goes into a drainage system.
Question: If the two of them are bolted to an isolation valve, and as per ASME B31.3 345.1.2 (d) (Unless specified in the engineering design, lines
open to the atmosphere, such as vents or drains downstream of the last shutoff valve, need not be leak tested) is this line regarded as open to atmosphere, or is it not considered to be due to the fact that it can be still isolated at the flanges and thus the open end can be exempted from pressure testing.
Please advise me on the correct understanding
