I am looking for a method of measuring runout on a shaft while it is rotating. The shaft will be approx 2" diameter, rotating 500RPM, and there may be a film of grease on OD of shaft. There is a small 1/4" dia hole providing access to the shaft from a housing that covers it. For a "static" measurement we are simply putting a dial indicator on the shaft and rotating the shaft by hand to get a reading. The problem is that I think the readings get worse under operating conditions but I have no way of measuring it. I am trying to resolve whether the shaft is running out, for example, .005" or .010", not down to 1 tenth.
Any ideas? The only link I can find is at
but it looks expensive and not really shop suitable.
Thank You
Thank You
