Measuring low current
beerbaron
37
Hi, I'm trying to measure the average current going to a LED that has PWM (100kHz). I used to use a 10 Ohm resistor and a 100uF cap in parrallel that I would put in line with the LED. Problem is that 10 ohm has too much impact on the circuit, using a smaller resistor like 1 ohm or .1 ohm would be perfect but then, how accurate is a digital multimeter when it come to 100uV to 100mV...
Any suggestions on how I can pull this off. Is there some good products around for my needs? Should I go with an Op-Amp ... I doubt an Op-Amp would be precise enough for uV and low mV ?
Frederic
OK, How about two thermal couples,
a resistor (the same as the sense resistor)
with a dc current.
Adjust the current until they read the same
temp.
Ummmm! Beeeeeer!
I think it is time to close this thread. The creativity/reality is getting out of someone's hands...
But I am all for the beer!
Gunnar Englund
Oh, come on Skogs.
Nobody has mentioned "Depth of water sensing".
thread240-58310
LOL
The thread that never died - and never dies...
Gunnar Englund
