Mechanical delay.
itsmoked
19,114
Long ago I saw one of these but now that I could actually use one....nada
I want to prevent someone from starting a motor more often than every 15 minutes.(EVER!)
I have electronic timing so I can start a 15 minute timer that prevents hitting start again until it times out. But you get the clever/stupid operator who figures out that if power is lost the timer resets. Then they just crank off the disconnect and then back on, and away they go with a 30 second cycle.
I have seen mechanical bellows(?)types that essentially cock with the initial turn on then take x minutes, regardless of the power situation, to re-close.
Anyone have a lead, or know what these are called? Or have an effective alternate solution? Google bombed for me.
Keith Cress
Flamin Systems, Inc.-
Hi Jeff,
Regarding arc energy: I'm no expert but I'm currently trying to raise awareness of the risks of arcing faults at our site. I thought the ratings were based on available fault level and protection characteristics rather than the amount of bare copper? Or are there a different set of regs I'm totally ignorant of? We're trying to apply the intent of the NFPA 70E standard on our British equipment and it is proving interesting. There is a lot of resistance to wearing the Category 3 and 4 suits because of the discomfort levels. A few have remarked that any task which is dangerous enough to require us to wear a 'space suit' should not be done live.
Sorry for dragging this OT!
image.php
I don't have an attitude problem. You have a perception problem...
Feel free it's no problem on the tail of this thread what-so-ever.
Those big fuses are current limiting and this panel is served by a 100A breaker. Seems like a substantial amount of limiting.
Hey Jeff, how about a napkin arc-flash calculation on this thing.
What info does one need to start with?
Or is it a royal pain in the butt-don't want to do it task?
Keith Cress
oooooooooo Scotty!
[surprise]
Some folks like myself have to troubleshoot and service (even occasionally modify or re-wire) equipment like this, and many of us HATE much imported equipment with IEC type components and practices, because accesibility is a consideration.
Yeah, that disconnect and the fuseblocks are really a bit much,,,, but it's no more dangerous than euro-stuff - always too tightly packed in - with the covers removed for troubleshooting, and test probes nearly touching each other and other devices because of those tight clearances.
...always too tightly packed in...
Bad design is just bad design, wherever it is built. I send designs like that back to the designer covered in red pen and rude phrases! I have to live with the stuff we design - I'm on call one week in six - so I have a take-no-prisoners attitude with designers who use crappy components loaded right up to their rating and who squeeze things in too tight.
image.php
