Mechanical design/Math rotating bars
pllmoreau
Member
Feb 14, 2017
33
Hello all,
I can't find the ralation between the movement of 2 bars that go in opposite directions that I need to find for a mechanism. I need to find the distance that the bar B will travel if I pull from the hole on bar A (see image).
Thank you!
There are entire books on mechanical linkages.
This is simple geometry.
You are actually interested in the movement of the hole in the end of "B" aren't you?
Hint: It's not a linear relationship for more than infinitesimal travel.
EdStainless yes I am interested in the movement in the hole in B
This is not unlike some of the mechanisms that I worked with when I was a machine designer. The primary purpose was to convert a constant input motion into a variable output motion. In fact, we patented a mechanism which we called the 'variator' that used this principle, that is a cam follower, attached to the crank arm on one rotating shaft, retained in a slot on a second crank arm attached to a parallel rotating shaft. The distance between the centerlines of the two parallel shafts determined the profile of the curve which represented the rotational speed of the output shaft relative to the rotational speed of the input shaft. Note that the length of the slot in the second arm was long enough that the shafts were able to rotate a full 360 degrees . This was used when we needed a portion of a mechanism to start slow, speed-up and then slow down again before the end of a cycle. The input shaft was driven through a single rotation clutch, which when activated only allowed the shaft to make one rotation. The clutch was cycled for each desired output cycle (I wish I had a picture).
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
You should know the distance between the pivots and the distance from the one pivot to the pin marked B. You know the angle of the slot relative to the baseline between the two pivots.
So, recalling that C^2 = A^2 + B^2 - 2 ABcos(theta) and you know C, you know A, you know theta you can calculate "B", the distance from the first pivot to the place along the slot the pin is. Knowing all three lenghts you can calculate all three angles; in this case the remaining 2 of which you are interested in only one.
