Looking for some help with reading this print? I have not had to much experience with metric prints, and mostly wondering about the toleranceing? Obviously you can convert the dimm. to inches but what about that tolerances? For instance it has .003 R/O on the cone, is that .003MM or what is that? same with on the Dia 16, -.001/-.005 is that +.001/-.005MM and if you convert that to inches that is really tight? Also in the title block it is in a different language but what is the mean there with +/-.1, +/-.2 etc?
