micro components to drive a shaft
sunclipa
16
Hi
can anyone suggest electronic means to rotate a small shaft? it has to be less that 5 mm in scalel. shaft diameter 1.5 mm ? load a couple of grams.
many thanks
Antoine
Sunclipa
Hi
i should explain more i want it to turn to two positions at 90 degrees to one another . time 0.5 second approx between two positions. not my technical area
thanks will look , smaller would be better
there are things called MEMs actuators. I wonder if they might be too small for your application though.
