I'm looking for any suggestions on milling carbon filled UHMW. The problem we are having is that the chips aren't clearing, and just "fuzzing" up. Using a 2 flute 0.218" dia ballnose cutting 0.046" dp with the tip, our max spindle speed is 5k and thats where we are running. I think the main problem with the process is that we are using a rotary table (max 15rpm rotation) to change part orientation during cutting, and the geometry dictates a feed of 3 ipm due to the ro-tab.
I am considering a vortex tube cold air gun, but don't think it will have sufficient velocity to blow the chips out before they re-weld theirselves back to the stock mat'l.
Svanden
Svanden
