Min vertical and horizontal curves
martin888888
157
Designing a 7000' private access road to a energy facility to be used by tractor trailers hauling fairly heavy loads. Would it be preferable not to use minimum vertical curve k values and minimum horizontal curve radius due to the vehicles using this road?
Minumum k values are based on stopping sight distance, not the size (or clearance) of the vehicle. If you use the minimum k-values the tractor trailers will have no issues with clearance (if that's what you were asking).
If you are concerned with stopping sight distance, due to the slower deceleration of these vehicles, then you should determine the stopping sight distance of these vehicles and adjust you k-value accordingly.
And depending on your design speed, the miniumum horizontal curve radii may require that you widen the road surface in the curves to accommodate the larger turning movements.
