Justice100
Chemical
- Jun 18, 2008
- 42
Hello all,
General advice for defining a control valve DP at design flow is 0.7 bar or 30% of total system DP, whichever is higher. For low pressure gas systems the minimum of 0.7 bar can be unachievable as it is not available. Can any one point me to guidance for defining this for low pressure gas systems or is just using a DP of 30% of total DP ok even if that results in a control valve DP at design flow of for example 0.1 bar? Would this need a special type of valve or would just a butterfly valve be ok?
