minimum bend radii for electrical routing using splines - NX11
laurens
NL
How do you set up minimum bend radii for electrical routing paths using splines? Is there a way to set up a minimum bend radius for each spline?
For example, if we are using some cabling that requires a larger minimum bend radius than other cables I want to be able to specify that without changing the system defaults for all electrical routing.
regards, Laurens
