Minimum Wall Thickness
sowhatso
99
I did a calulation to know the minimum wall thickness required for carbon steel pipe (ASTM A53 Gr.B , type E) that will be used for potable water pipes.
I did the calculation according to two ASME codes :
ASME B31.1 : Power Piping
ASME B31.4 : Pipe line transportation system
The calculated minimum wall thickness according to the first code (ASME B31.1) was much greater than the MWT calculated according to the second code , is that because the power piping code assumes that number of joints , valves ,and fittings existing much more than that at the pipeline ? Inaddition , the allowable stress value (S=25,200 psi ) at the first code was higher than the maximum allowable stress at the second code (S=12800 also) , Moreover , the weld joint efficiency factor at the first code is 1 , while at the second code 0.85 ? why we have this difference if we are dealing with the same material ?
Per Table A-1 of B31.1, the design allowable stress for A-53 B Class E is 14.6 ksi at T < or = 650 F. The .85 E factor has been taken into account in the design allowable stress. Design allowable is based on a Safety Factor of 3.5 on the minimum specified tensile strength in that temperature range.
Other Codes use different design allowables based on different Saftey Factors (3:1 for B31.3) or are based on a percentage of specified minimum yield strength (B31.4 & B31.8).
Codes are written by people who represent companies and Jurisdictions with materials in differing services and margins of safety or additional inspection/testing criteria.
Dear stanweld ,
According to the ASME B31.1 (Version 2001) , the maximum allowable stress for ASTB A53 Gr.B , Type S (Seamless ) , is 15 ksi , and for Type E ( Electric resistance welded pipe) is 12.8 ksi, maybe for new update version it is different.
The design allowable stresses quoted are for the current edition. And yes, the Safety Factor changed from 4:1 to 3.5:1.
