mixing time calculations of jet mixers 1
mo.kazemi
4
hello
how can you calculate the time mixing of 250 m3 storage tank with a high viscosity liquid (350 cp)using the jet mixer?
Good luck,
mohsen
The starting point is that you must know the amount of flow that you are putting through the jet mixer.
Ashtree
"Any water can be made potable if you filter it through enough money"
Have you selected a jet mixing correlation? If so, please share it.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
No, the available correlations didnt considered viscosity parameter and used for turbulent regime.
I have experienced the same problem. I ran the numbers on your tank in my spreadsheet. Jet mixing works best when the jet Reynolds Number and tank Reynolds Number are both turbulent. The best I could do was the tank was laminar and the jet was transitional. It doesn't look good for jet mixing. It's too far removed from the design basis. Have you considered a mechanical agitator?
Good luck,
Latexman
I didnt considered agitator.in my study, jet Reynolds Number is approximately 2000.based on your experiencs, which one equation can I apply for solution of this problem, do you have applicabe document to help me?
Good luck,
mohsen
Yes, I got a jet Reynolds Number of 1480 for a 1.61 inch nozzle outlet diameter. Our design guidelines on jet Reynolds Number are > 10,000, if possible. No, my spreadsheet/technology belongs to the company and their fluid flow technologist. The reference given is Mixing in the Process Industries 2nd Ed. by Harnby, Edwards, and Nienow.
Good luck,
Latexman
