I wanted to model an 8.67' X 31.5’ concrete slab with a 16,000 lb. load applied at the center and nothing else.
I did not apply any self-weight or load factors in this exercise
The slab will have fixed ends at all sides.
Can anyone explain why I am getting apparently a very low maximum moment of 2.3 k-ft/ft.?
As a “one-way slab”, the expected max moment utilizing manual calculations is about 17.3 k-ft/ft; by using the formula (PL/8 for fixed ends), where L=8.67’, P=16 kip, and by neglecting the self-weight
** Does the moment I am getting sounds right? And is it acceptable to design for?
I appreciate any help... Thanks
