AbaqusBeginner
Aerospace
I'm currently seeking to model the failure of a carbon-epoxy plate with a circular cut-out in the centre under tensile loading, this is my first time working in Abaqus, I'm using v6.9, and use CAE.
Currently I've used S4R shells in /Explicit and one integration point per ply in the layup. I'm using the Hashin criteria and linear damage evolution model with some apparent success.
Currently I'm applying a fixed boundary displacement with a linear amplitude curve over the run time.
So a couple of things,
A) Is this the right way to go about this? Ie. using a fixed displacement BC?
B) I would like to extract the failure stress of the panel, any ideas as to how to go about doing this?
C) Whats's the best manner in which to assess the overall failure path? I'm currently looking to the 0 deg ply for this and it is showing failure in the transverse direction, the experimental results showed a failure path approx 22 deg from normal.
D) I would also like to move to a 3D continuum shell model. Am I correct in saying /Explicit can handle only single-ply continuum shells and hence would need a layer of elements per ply?
E) A step further would be modelling delaiminations - could this be achieved by layers of cohesive elements between each continuum element ply? What would be the easiest way in which to go about this?
Any tips would be greatly appreciated, on points I've mentioned or just anything in general that I may be doing causing me to go awry, as this is my first real experience with Abaqus.
Currently I'm stumped trying to evaluate panel strength, and the issues with the crack path.
Thanks for your time and assistance.
