smb_PE
- Mar 12, 2018
- 6
This is my first post, so forgive me if I started this thread in the wrong location.
I'm looking for modeling tips for a fairly complex building structure. This building will have floors that ramp to accommodate levels for an existing building. In addition, there are certain areas where the diaphragms are vertically offset by 5' or so in the transition area. My main question is how can an analysis model be tweaked for this case?
In RAM, adding extra stories leads to multiple short columns, which make the design process difficult if sizes need to be tweaked in RAM Frame. I know in RAM Column, we can de-select 'floors brace columns', but there does not appear to be a good way to do this in RAM Frame.
It has been suggested that ETABS could handle this problem better than RAM, but I don't have enough ETABS experience under my belt to know if it would be worthwhile. I also have access to RISA Floor/3D but am doubtful of RISA floors composite design capabilities. Any guidance is much appreciated!
