Moldwizard Multiple Images on Parameter
vegetagaru
Computer
Jan 14, 2015
134
Hello all, i was wondering if there's a possibility on Mold wizard Standard Part to have the main image, then when i select a specific Parameter of that part the image changes to address the selected Parameter.
NX8.5 - NX9 - NX 10 - NX11 - NX12
BETA TESTER: 11 - 12
Yes you can do that.... you need to call out the bitmap image in the spreadsheet.
You could have one for each row in the list.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
If I remember right...
You need column called "Bitmap"
If the Bitmap is in the same folder as the re-use part.... just put the filename of the bitmap image in the Bitmap Column.
You can have them in sub-folder
But you need this syntax .../My_Image.bmp
If that's not exactly right, it close
Dave
NX11, Win 10 Pro
thank you for the effort 3dr but i think you understood wrong :p i want a bmp for a specific parameter (Collum) not for a different configuration(row)
imagine that the user is inserting a "CAR" (appears a car image") but when selecting the tyres the Bitmap changes to a tyre bmp i will try to upload a image to better explain my self
