Viper488
Automotive
- Jun 4, 2004
- 40
Okay, here's an engine with hypereutectic AL pistons traditionally said to be limited to 5psi from a DIY blower kit using a Whipple blower.
Setting that aside for the moment, but keeping that limitation in mind, what's the difference between adding ported heads to that 5 psi s/c engine, or just changing to a smaller 7psi rated pulley with unported heads?
Net operational psi is a function of backpressure/restriction in the head isn't it?
I haven't heard any objections to adding ported heads to a 5psi s/c setup, but that would have to raise cylinder pressure wouldn't it? - At the same time lowering measured blower (back)pressure.
Yet a '7psi' pulley blowing through un-ported heads isn't putting as much volume into the cylinder perhaps. Depends on whether the s/c vendor has designated that 7psi pulley from testing on an engine with ported heads or not I guess eh?
How different is a psi pulley on ported heads from a 7psi pulley in unported heads??
