I have a Blower motor that we are having problems with. We monitor the pressure in the pipe going to the cyclone. If the pressure gets to 5 PSI we shutdown the feed, if the pressure gets to 7PSI we shutdown the blower motor. Last week we had a small hole in the pressure line going to the pressure sw causing incorrect readings, causing us problems. My boss now wants to install current xmers and program using the amperage readings.
My question is as the motor gets older, heats us, etc the amperage should go up. The motor on the blower system now gets very hot,and if pipe gets plugged smokes quite heavy.
The amperage should go up if the resistance is going down in the motor.
