I need to spec differential CTs for a 3400kW Induction motor. I wish to use 3CTs instead of 6 (by running the phase and neutral through one CT. The FLC is 204A. The CT supplier is asking for a detailed spec before they make the CTs to order. They need knee point voltage as well as volts per turn. Accuracy class is ClassX - or the equivalant. The fault level is 8kA for 3ph and 3kA for 1ph fault.
Kevin Bosch
Rainbow Technologies
Kevin Bosch
