  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Move detail view
skadborghansen
Marine/Ocean
Oct 29, 2009
Hi
Does anybody knows if it's possible to move a detail view (simple stepped section line)
from one parent view to another parent view. I have the same geometry in both views
When I delete a parent view my detailed view will be deleted as well.
I know it's possible to select view boundary on the section views parent view and make the parent view very small so all the lines in the view will be hided and then move the section line to another view, but I would prefer a methoed without all these "empty" views.
Hope someone has a solution.
Sorry, but there is no mechanism in NX which would allow you to reassign (change) the parent view of an existing Section View.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Just move the parent view to another sheet if you don't want to see it. Alternatively you might just edit the view boundary so that it is reduced to white space and nothing of the parent view appears on the drawing. Lastly you can convert the view to reference so that it exists but doesn't appear.
If the base view has section lines you can display the label on the section view as you may wish (or not) but by editing the style it is possible to set the section lines themselves to No Display.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
