Movement Damping In Pressure Gauge. 1
shiplu48
Chemical
Dec 3, 2016
43
I have come up with a pressure gauge data sheet and found a parameter called "movement damping".
What does "movement damping" in pressure gauge really means in data sheet?
I have gone through that term and found out that "Dampened Movement" minimizes effects of vibration without liquid filling.
Although I have found out that PG is filled with "Glycerine" and "Snubber" is used for reducing pressure fluctuation.
Uses of Glycerine has already provided the advantage of dampening properties to needle movement.
Does it mean uses of another accessories to dampen pointer movement?
Thanks in Advance.
shiplu48
I know Wika has a dampened movement that was developed for applications that could not use liquid case filling. They mount a mechanical dampener right on the pointer shaft (like a dashpot).
Link
If the manufacturer can't tell you what makes their dampened movement a dampened movement, then it's probably just the combination of the liquid fill and an orifice 'snubber' in the socket.
Thanks danw2 for your valuable input.
If the gauge is filled with liquid (glycerine) then I don't need to use movement damping.
If there is restriction to use liquid then I have to move for that movement damping.
