Moving Views between Sheets??? 1
Jalipa
Materials
Jun 5, 2001
35
0
0
GB
I have a drawing of several sheets.
I need to move a a view from one sheet to another...but don't want to have to re-create it and all of the dimensions
Any idea how?
I tried cut & paste but that doesn't seem to work.
Thank in advance
J
Using Wildfire, select the view required, select EDIT from the top menu, and select MOVE ITEM TO SHEET.
Hope this helps.
maybe only a drafter
but the best user at this company!
Thanks Only....
I knew it could be done....just didn't know where the command had gone.....that and a deadline.
Still not used to this darned WF....and it's been a month since we switched!
In Pro-E2001
Create the new sheet (if not created already)
select - sheets
switch sheets
dwg views
select view to be moved
done
done
specify destination sheet #
