MPLAB CODE
pampam
can anybody help in coding of frequency counter using PIC16F877 using MPLAB. frequency is supposed to display on 4 digit 7-segment led.
No this is not for school. Actually this is for the our company and I am an employee. Giving you more details of my project- I am using signal generator to apply different kinds of waveforms(sinusoidal, square)applying to PortC and using PortD as output to display frequency on 4-digit 7-segment LED.
Awaiting for your reply.
thank you
Somebody has done this allready, search around and you should find it. You cant get much in the way of high frequency measureing, somewhere around 80kHz if i remember right.
80 kHz max? Is that all? Yikes. Circa 1980 I did up an audio frequency counter (sampled port) using a ~1 MHz MC6809E and it covered into (at least the low end of) tens of kHz. That's over a quarter century ago.
