Mohamed Mowafy
- Mar 6, 2023
- 9
Hello, I have a patran model and have assigned the subcases and sent them to Nastern for analysis.
I have imported the results from the.XDB file in Partan for review, and I found a new subcase has been generated with the same ID, but the software adds SC before it.
For example, I defined a subcase called SLS1, and the software generated a new subcase called SC:SLS1.
The problem is that the results are different in the same cases. SLS1 and SC:SLS1
For example, the deflection in case SLS is 6.5 mm, while in SC:SLS1 it is 4.6 mm.
Anyone have any clue what's happening here?
i attached a pic show the generated load cases
thanks
thanks
