Multi Cycle Analysis 1
brahmabull525
During a recent meeting, a consultant mentioned "Multi Cycle Analysis" as a time study method. Does anyone use or know where I can find information on this method?
Any info would be appreciated.
Thanks!
It might be a hook thrown out by the consultant to get additional work using a "unique" method they may have created. I did not find anything remotely close using a couple of search techniques
Or from the sound of it, it might be an time study run multiple times with all variables independent (setup, operator, materials etc). Last thought would be a full workflow analysis of all activity related to the product.
Hey Bramabull,yes a Multi Cycle Analysis is just another term for breaking the job into elements and taking cycle times of each respective element then averaging and combining those times to create a standard time for the job.I have used this method for years where the flow of the job is spread over a distance that would require the observer to move up and down the job route to see all of the job within a radius around him/her.
For instance were you to study the flow a box placed on a 400 foot conveyor belt that required the employee to both load and unload you could see part of the job but not all of it unless you followed the employee,so the Multi Cycle Analysis allows you to time just the element of placing the box on the belt,after accumulating multi cycle times for that element then you move to the next element or part of the job etc etc.The 1956 edition of Maynards book on Time and Motion study has a chapter dedicated just to this method of time study.Hope this helps.
