BadgerPE
- Jan 27, 2010
- 500
Hey all,
I have never designed a multiple course CMU lintel before without just using 16" U-shaped blocks. What is the typical way to construct a simply supported lintel with say 3 courses required? Would you first place a set of 8" U-shaped blocks with reinforcing, place two more courses of standard blocks above, and grout the whole thing solid? What about continuous lintel? Would you knock out the webbing of the standard blocks to place top reinforcing where needed? If anyone has a sketch or a standard detail they are willing to share, it would be greatly appreciated!
