JBUDA54
- Aug 7, 2001
- 110
I am currently on a design/build project writing some specifications on Medium voltage motor control centers/Cable/Motors. There was a recent discussion within my group about when to use shielded cable for medium voltage loads. According to an article written by John A. DeDad Editorial Director for EC&M, he makes the following statement: "As we all know, the metallic shielding in a medium voltage (MV) cable provides the necessary uniform electric field within the cable's insulation." See the following website for a write up of his article: It can also be found in the EC&M Feb 1, 1995 Magazine Issue Titled "Ground-fault coordination should include MV cable shielding." My question is what dictates when shielded cable should be used? I realize that cost dictates some projects as to how stout an electrical system should be installed as far as the implementation of good engineering practices, but is there a standard that governs this area? A senior electrical engineer told me that shielding should be considered for loads voltage levels above 2400V. Any assistance with this subject would be greatly appreciated.
Jason Buda, PE
Greenville, SC
(864) 676-6458 PH
Jason.Buda@Jacobs.com
Jason Buda, PE
Greenville, SC
(864) 676-6458 PH
