ChrisKn
- Mar 26, 2005
- 19
In a typical one story building with a joist girder/joist/steel deck roof system supported by on interior columns and exterior CMU walls, what kind of wind loading do you consider for design of these items??
CMU walls - MWFRS
Columns - MWFRS
Girders/joists/steel deck - MWFRS or C+C - The roof diaphram as a whole transfers wind loading back to shear walls, therefore are each of these items designed with MWFRS.
My confusion primarily lies with the roof system since to me they act together to transfer wind loading but as seperate items (not working together as a diphram) they would be more under a C+C item? So waht loading(s) would you consider when designing these items?? Also what are the thoughts of connection designs of the deck to the joist and the joist to the Joist girder and teh joist girder to the walls? I have heard two schools of thoughts on these connections as well and to me it seems that these connections shoudl definitely be designed to resist the C+C loading.
So waht are your thoughts on this subject??
Chris
CMU walls - MWFRS
Columns - MWFRS
Chris
