PoorManagement
Automotive
I'm having trouble understanding how an engine can produce more power boosted vs naturally aspirated.
I'm assuming that an ideal NA motor - let's say a 2.0L making 220hp is doing so at the limits of the structure of the engine - for arguments sake, with cylinder pressures of 120 bar.
Now you add boost, and the engine can make 400hp.
But the structural limit of the engine is still 120 bar before parts fail.
Is it possible that peak cylinder pressures are roughly the same? (I'm missing a relationship between peak cylinder pressure and mean effective pressure - work done as the volume expands)
How is the additional power achieved while keeping peak cylinder pressures at a level that does not hurt the engine? Spark retard reduces the absolute peak pressure, but the pressure for the entire combustion cycle is higher overall? (Higher MEP?) Is this my answer? I think it is...
I'm assuming that no other physical changes are made - same pistons, rods (so same compression ratio), block, heads, etc.
Assuming the boost device provides additional air at a reasonable temp (intercooled), and the fuel system delivers the appropriate amount of fuel for the available air...
Thanks!
