Hi, folks,
I have a question regarding wire sizing per NEC.
UL requires hazardous voltage circuit conductors supplying one motor shall have an ampacity not less than 125% of the motor full load current rating. Does NEC have the same requirement? I found ampacity table 310-16 &17 in NEC 2005 but could not find the similar statement regarding if I need to use 125% factor.
Thanks in advance.
Thanks in advance.
