I need a 1" 15psi soft seal pressure relief valve.
We are building a high voltage test chamber that will be filled with sulfur hexafluoride (SF6) to prevent arching. The plan for the chamber is to pump it out to around 10^-3 torr or lower (aka higher vacuum) then to fill it with SF6 up to 1 atm (gauge pressure not absolute). My understanding is that if the pressure is kept below 15 psi above atmospheric pressure we do not have to certify it as a pressure vessel so that's the reason we need the relief valve. We bought a kunkle valve from mcmaster carr ( and when we tested it we realized it did not hold pressure and started weeping well below 15psi. So I need help in finding a soft sealing (because it has to hold vacuum) 15psi pop safety valve. It can't start weeping much before 14.7 psi.
Thanks,
Steve
Thanks,
Steve
