MR76
Automotive
- Dec 4, 2015
- 10
hello everyone!
Does anyone know how to "ask NX" for an empty, or less populated, area of a drawing ?
I have developed a journal, which reads data from an excel, and assigns this data to a tabular note with attributes (stamp), which I then insert in the drawing, and print in pdf. (the journal runs over 100s of files)
These drawings are "customer drawings", (I can't change them) so I just print them (pdf, dxf) with the stamp.
The problem is that am putting the stamp in a fix point of the sheets, (let's say in 5,5,0), but many times in this point there are texts, or views.
I have tried to put a background to my stamp without success (images, shading...).
(a workaround to this solution could also work for me)
So I decided to ask if anyone knows how to insert the stamp in the "less populated area" (empty if exists) of the drawing.
I only need a hint... !
thank you all very much!
