Need inexpensive SSOP test clips
MacGyverS2000
8,504
I'm looking for inexpensive test clips for SSOP/TSSOP packages, starting at 14 pins in size and going up. I've found plenty of SOIC clips for decent prices ($10-$20), but the leats expensive SSOP I've found was by Pomona at nearly $300! I've also looked at Emulation Technology clips at roughly the same price range.
I don't need Ghz range clips... these are for programming processors already on PCBs that run in the 20MHz range. At that low of a clock, it should be obvious the slew rates aren't going to be that high, so claiming GHz range on clips for a higher price doesn't do me any good.
Anyone know of some?
Hi, you need to route the programming pins to a conventional socket or edge connector, I know that's not much help if you have made the board allready. A similar situation exists if you need to attach test gear such as logic analysers to your board, same solution. Moral is to plan ahead.
The larger boards have this, but several products have minimal size as the leading goal (hence the use of SSOP). Even with the 2mm pitch the larger boards use, a 5-pad bare board connector would increase board size by at least 10%... that's a definite no-no.
Unless somone is able to provide me with a useful and inexpensive socket, I'll be forced to kludge it. Even though looking for a socket for SMD chips is somewhat pointless, I did it anyway, just in case.
If I can find something with the same pitch, I may be able to finagle something together. I was thinking about some board-to-board connectors by Logical Systems with the same 0.65mm pith as SSOP. The females are only 3mm inside rather than the typical 5mm of SSOP, but maybe a good dremel tool cut down the center and some extra plastic would do it up nice. For a couple of $, it may be worth a try.
I'd still pay the extra dough for a quality, purpose-built connector any day, just not $300 worth of extra dough.
Hi, an alternative is to have a standard edge connector, once you have programmed the processor you cut the edge connector off, not too good if you need to upgrade later.
It's upgrades that I'm working with here, unfortunately...
In that case as it's just a small board why not replace the whole board.
Expensive components, and any replacement board would need to be the same size, so if another upgrade comes along, I'm in the same position.
If all the boards are identical, then find available traces to make contact to, measure carefully the locations, buy some small pogo pins, use a piece of delrin, and make a simple pogo pin fixture.
You might also be able to use zebra-strips to a contact board directly above the chip to make contact to the pins. Again, careful positioning and fixturing may be required. Just a quick idea I've never tried myself.
