Negative eigenvalues 2
Senad83
NO
Hey,
I'm doing buckling analysis with 5 eigenvalues. One of the is negative, but my analysis still completes with out errors or warnings. Does anybody know how I can avoid the negative eigenvalues?
Senad
Arbor,
Assuming you have modelled the whole pressure vessel then the vast majority of your structure will be in tension, hence the many negative eigenvalues found by Abaqus. There may be a considerable number of these encountered before Abaqus spits out the positive eigenvalue you seek. I am not aware of any means of suppressing negative eigenvalues. Have you considered running a static large deflection non-linear analysis using NLGEOM instead? This may be more appropriate than a buckling analysis for this type of problem.
johnhors,
You are right about my model and the eigenvalues. I have several approaches to check different failure modes of a pressure vessel based on ASME code. The approaches include linear elastic and non-linear plastic analysis. The code also requires to check buckling when there is compressive stress. There is no very good analytical solution for head knuckle buckling load. So I am trying to see if ABAQUS can help for this case. Thanks
Arbor
