mc02076
- Nov 7, 2008
- 7
Greetings,
I need to select a motor for an mechanical press application.Its nothing fancy, a 1.5 kW motor will do plus I need variable rpm and a max/min rpm ratio of 60.
So,from what I have read,I can either use a dc motor or an induction motor with motion control,the latter being a better choice as they can go up to an rpm ratio of 1000 (or so I ve heard)
However,while browsing all the manufacturers at global spec,I have found 2 types of induction motors.The ones that are referred to simply as "induction motors" for whom there is no definition over the max and min rpm but only a fixed rpm value for a fixed AC frequency, and the so called "variable speed induction motors" for whom the rpm ratio is 2 to 4.
So I guess my question is this:
Can all induction motors be controlled with an inverter? if so,how can one calculate the rpm ratio that can be achieved?
Thanks in advance!
Thanks in advance!
