No solution found - MathCad 14
djt123
Bioengineer
GB
Can somebody have a look at this?
This uses a solve block and an equation created with a boolean equal to solve for an unknown.
I want to solve for n and for different input values. This works for f := 1 but not f := 2 or f := 3.
I'm not very familiar with MathCad so this may not be the best approach. Any advice would be appreciated.
Daniel
The way you had set it up, n has to be an integer (factorials aren't defined for non-integers) and Mathcad isn't good with diophantic equations, to put it polite. Furthermore I guess, you can't expect an integer solution for n anyway - it doesn't exist and thats exactly what Mathcad tells you. You may also simplify and rewrite your equation using Mathcads built-in function for the cumulative binomial distribution "pbinom()" but you won't get a solution either.
In case of your function I was successful replacing the factorials either with the appropriate Gamma functions and also by replacing them using mathcads built-in "combin()". The latter did surprise me as combin() won't work with non-integers, too.
The solution of course is a non-integer and for some reasons beyond me, the symbolic eval would only yield negative solutions (which are correct anyway) for odd values of f and refused to respect a n>0 constraint or an equivalent "assume" statement.
Nevertheless the numeric evaluation, given a positve guess value, always seems to return the prefered positive solution.
 http://files.engineering.com/getfile.aspx?folder=700b3b87-9549-437b-bcd9-c3a23a6b441d&file=Test_2.xmcdz
Many thanks for this!
Your comments are understood and explanation clear. Thanks for providing the updated MathCad file.
Daniel
