nonlinear using professional
craigj
31
Hi Group,
Question. I just bought a license of Ansys Professional and am having trouble with the "large deflection" solution setting. My VAR's technical guy told me that a professional license may only support geometric nonlinear options for shell elements not solid. Is this right?
I looked at all of the Ansys capibility charts and they do not specify this little detail.
Has anyone delt with this before?
CJ
You can carry out a geometrically non-linear analysis with your professional licence using both solids and shells. However, there are some restrictions on the type of elements you are able to use within your professional licence remit (cf. SOLID185 and 186). What problems are you experiencing with the solution options?
-- drej --
Hey Drej,
In workbench I select "large deflection=on" in the solution options...at that point the cells turn yellow and a little red explimation point appears in the solution tree. It will not let me solve.
In the classic enviroment I get this message when I go to solve:
"The SOLID186 option NLGEOM=1 was either not ordered with the ANSYS installation or the appropriate product was not selected for this session..."
Am I using an inappropriate element type for my license? In workbench I dont think you have the option to change the element type, but???
Thanks for the input,
CJ
one more thing:
When I mesh in Workbench an transfer to the ansys classic the default element type is someting called MESH200...what type of element is this?
MESH200 elements are known as "Unsolved" elements since they are used only to mesh a body (they play no part in the solution). These elements can be line, 2D or 3D in formulation, and are used in situations where you need to sweep or extrude a mesh from 2D to 3D (for example). You can unselect/delete these in classic before solving if you wish, otherwise don't worry about them.
You can choose different element types in workbench depending on the mesh properties you've specified. For instance, if you have a hex dominant mesh, you can choose either first (reduced) or second (full) order quads (185 or 186) - see the element integration scheme in the details sections of the mesh in workbench. The issue surrounding your NLGEOM message is strange. It appears as though you don't have the licence capability for NLGEOM - check to see which licence you're picking up by looking at the top of Workbench or manually configure Workbench first.
I just checked out my support. On their charts for the professional version it's written that the nonlinear geometrical capabilities are large deflection only for beams and shells and stress stiffening for beams, shells and solids. This seems to confirm your suspicion.
