Hi - not sure if this is the right place for this question, but I figured I’d give it a shot.
Ideally if you have experience in Ontario, that would be helpful! I’m trying to determine when a notice of project (NOP) applies on an industrial site. If labour + material costs exceed $50k for a non automotive plant, you need an NOP. In a large repair project, it seems the activity should be covered by construction regs as opposed to industrial. My question is - do you consider the cost of the part being replaced as a “material”? So - if I’m replacing a large screw as part of a screw conveyor and the screw costs more than $50k, do I need an NOP?
Thanks!
Thanks!
