My client asks to check rating flange against Nozzle loads equivalent pressure combined with equipment design pressure.If it fails check the flange as per ASME Sec VIII div 1 appendix 2.
For establishing equivalent pressure due to Nozzle loads Kellog's formula is generally used by pressure vessel designers. However this has not come into the codes?
In my experience when a rating flange is checked as per ASME Sec VIII div 1 app 2, it generally fails since allowable stress of ASME pressure vessel code is different from ASME Piping code.
However when a particular nozzle flange fails in the above conditions, can we design the flange as per ASME Sec VIII div 1 App 2, with allowable stress as per ASME B31.3 in consideration of para 304.5.1 where it allows such method. If it still fails, there is no other option except to enhance the pressure rating of the flange.
