waliq
- Jan 28, 2019
- 53
We want to cut 02 nozzles of NPS 3" each in an existing stack. The nozzles are instrument nozzles
Diameter of stack : 1350 mm
Design pressure : Atm
Operating Pressure : 280 Deg C
MOC Stack shell : Corten steel (Grade not available in drawing)
Thickness of shell : 10 mm
My questions in this regard are as follows
1) Can I use SA 106 GrB and SA 105N flange and blind flanges for nozzle material?
2) Should we perform a stress analysis for cutting holes in an existing stack to install 02 nozzles?
