alpha0125
Chemical
- Mar 2, 2015
- 17
If we have 50 psi seperator with gas, water and natural gas condensate(oil), the gas seperates and goes out from the seperator from top. The water and liquid comes out from the bottom. If i need to transfer liquid from the seperator to 200 miles far to the tank, then i need pump to transfer the liquid because of pressure drop on the pipe.
if there is a 15 feet tall seperator, and the top level of water is at 12 feet and and top level of oil is at 15 ft (which is total of 3 ft oil). I want to pump all 3 feet of oil and i want to pump 5 ft of water everytime pump kicks on. The specific gravity of water is 1.14 and specific gravity of oil is .742.
I know how to calcualte the NPSH.
how much head do i have to use to calcualte NPSH? I think i need to calcuate NPSH for oil and NPSH for water and add it. For NPSH for oil , what is my suction head becuase i only have 3ft of oil and i want to pump all that. if i stop my flow when water level gets to 10 ft that means i do not have any oil left. I thought my suction head is whatever the differnce in the liquid level ( for water case, 1O ft becuase i stopped my pump at when water is at 10 ft).
1) What is the for the oil case?
2) My question is since i have water and oil in the vessel, the vapor pressure of of both od them is 50 psi. if oil is saturated at that pressure, what happens to the vapor pressure?
Sorry if it is dump question, i am recently graduated engineer.
