NX 10 Macro/Journal to create assembly parts
Vrpeng-tips
14
Hi guys,
I am using NX 10 and I need to create a top down assembly.
I have created skeleton in my assembly file. (This contains hundreds of connected curves )
What I want is, when I select one curve, I should be able to add parts (beams/extrusions) of the same length as of selected curve.
Each curve is of different length.
Can this be done using Macro/Journal available under tools option.
Thanks,
Vishal
Have you looked at the NX Routing Mechanical application?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
I have not looked into NX Routing Mechanical application.
I will have a look and if that do not work, I will come back for alternate solution.
Thanks,
Vishal
Hi John,
I tried Mechanical Routing, seems pretty good. But I am facing following problems,
1. Actually I want to do a Top Down design of structural building. This consist of plates and columns at diff. angle and diff. location.
2. In Mech_Routing when I place parts, it creates stock not the assembled part. (edited - well somehow looking at standard library components, I think I can bring my parts as fittings rather than stock. But still I will have to figure out.)
3. The placed stock is aligned/placed according to the path. But I want it to constraint with surrounding plates.
I am also not sure if Macros can do this.
Any suggestions would be greatly appreciated.
Thanks in advance.
Vishal
