NX 12 Sketch environment
Suren Bala
Automotive
Nov 26, 2019
I am a beginner in NX. Am using NX 12. Trying to create a solid model, while i used to Dimension inside the sketch environment am unable to select the edges of the base solid profiles. I just wanted to know how to enable the edges selection inside the sketch environment. Already i have enabled all options like Mid point, End point in selection group, kindly share you comments to enable the edges selection while dimension
Make sure that your selection preferences are okay.
This means, it should not be set to "Within Active Sketch Only"
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
