NX 9.03 - Point in Sketch and negative draft
ZikiJM
Automotive
Aug 13, 2014
9
Hi all,
1. After updating NX9 to last built 9.0.3.4 there is a situation, when I want to make a point in a Sketcher...
I click to "Point" icon and to a display space as normally. After that I have always 2 points in the Sketcher - one click -> two points on the same position.
Do you have somebody the same experience?
2. Is possible to make a negative draft in NX9? ...like in Catia?
I can't make a draft < than 0.
For example...I have a cylinder and I want to make a shape like drop in top view with Draft Body function
Thank you in advance for answers
Jan
As to the two points, don't use the Cursor Location icon, use Inferred Point.
NX 9.0.3.4
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
Thanks a lot [thumbsup2]
I will not ask you why ;-) There is so many "why"...
...I need use the same direction. Attached you will find a picture with the needed shape.
getfile.aspx
