NX Documentation 1
amitpaul713
30
I have installed NX 9 + Documentation in windows 10 but I cannot open the documentation. That is when I try to open NX documentation, it opens via Microsoft edge as default and then the page is just blank. Any idea why this happens? Answers would be highly appreciated. Thanks in advance.
Amit Paul
Set Internet explorer as default browser in windows...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Thanks for your reply. When I set Internet Explorer as the default browser, it shows enable java script while opening the documentation. But I have already enabled java script every possible way. I did the same with chrome too but was unsuccesful.
Amit Paul
If the docs you're trying to open are in CHM format, this is the source of your troubles. CHM files can contain malware, so Microsoft makes it inconvenient to open them. You have to loosen up some security settings. Search around the net for "CHM file not displayed" or something like that.
Since we put the docs on a web server, I don't install them locally anymore, and save a lot of headaches.
If you have a webkey account and decent internet access, try the online NX Documentation
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Hi markrief,
I do have a web key account. So how does the online thing work? I mean isnt it the same installing online or offline?
Amit Paul
By using the link Mark posted, you are accessing the documentation on a Siemens hosted server.
You always have the latest documentation available and no local install issues.
Ben Loosli
