NX Journal Question - Update Weight Data Now
alj722
Aerospace
Nov 4, 2004
39
I have kludged together a Journal from various sources to assign a mass to a body by calculating the density from the volume. It is pretty clunky, but does what I need. The only hitch is I can't figure out a simple way to execute the "Update Weight Data Now" command. When I record it I get 139 lines of code for that single command. Does anyone know a simplier way to execute that command in a journal? Below is my code (apologies to those who actually know what their doing with VB):
[pre]
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports NXOpen.Annotations
Module AssignMassToBody
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim dblMass As Double = 10.0
Dim dblVolume as Double = 1
Dim dblDensity_kg_mm3 as Double = 0
Dim dblDensity_g_cm3 as Double = 0
Dim iBodies(0) As IBody
Sub Main()
' Select the Part
Dim theBody As Body = select_a_body("Body:")
If theBody IsNot Nothing Then
Dim mm As MeasureManager = workPart.MeasureManager()
iBodies(0) = theBody
Dim massUnits(4) As Unit
massUnits(0) = workPart.UnitCollection.GetBase("Area")
massUnits(1) = workPart.UnitCollection.GetBase("Volume")
massUnits(2) = workPart.UnitCollection.GetBase("Mass")
massUnits(3) = workPart.UnitCollection.GetBase("Length")
Dim mb As MeasureBodies = mm.NewMassProperties(massUnits, 0.99, iBodies)
Echo("Volume = " & mb.Volume.ToString() & " " & massUnits(1).Abbreviation())
Echo("Current Mass = " & mb.Mass.ToString() & " " & massUnits(2).Abbreviation())
dblVolume = mb.Volume
End If
' Input the Mass
Try
dblMass = NXInputBox.GetInputNumber("Mass (kg):", "Input Mass (kg)", dblMass)
Catch ex as Exception
MsgBox("Something Went Horribly Wrong", MsgBoxStyle.Information)
Return
End Try
' Calculate the New Density
dblDensity_kg_mm3 = dblMass/dblVolume
dblDensity_g_cm3 = dblDensity_kg_mm3 * 1000000
Echo("New Density = " & dblDensity_kg_mm3.ToString() & " " & "kg/mm^3")
Echo("New Density = " & dblDensity_g_cm3.ToString() & " " & "g/cm^3")
' Apply the Density to the body
For Each obj As Body In theSession.Parts.Work.Bodies
If TypeOf obj Is Body Then
ufs.Modl.SetBodyDensity(obj.Tag,UFModl.DensityUnits.GramsCentimeters, dblDensity_g_cm3)
End If
Next
' Update Weight Data
End Sub
Function select_a_body(ByVal prompt As String) As Body
Dim mask() As Selection.MaskTriple = {New Selection.MaskTriple( _
UFConstants.UF_solid_type, 0, UFConstants.UF_UI_SEL_FEATURE_BODY)}
Dim cursor As Point3d = Nothing
Dim obj As TaggedObject = Nothing
Dim resp As Selection.Response = _
UI.GetUI().SelectionManager.SelectTaggedObject("Select a body", prompt, _
Selection.SelectionScope.AnyInAssembly, _
Selection.SelectionAction.ClearAndEnableSpecific, _
False, False, mask, obj, cursor)
Return obj
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
Sub Echo(ByVal output As String)
theSession.ListingWindow.Open()
theSession.ListingWindow.WriteLine(output)
theSession.LogFile.WriteLine(output)
End Sub
End Module
[/pre]
This code updates the mass of the work part:
Code:
' NX 10.0.1.4
' Journal created by jevtho04 on Fri Jul 10 21:49:42 2015 Romance Daylight Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim objects2(0) As NXOpen.NXObject
objects2(0) = workPart
Dim massPropertiesBuilder1 As NXOpen.MassPropertiesBuilder
massPropertiesBuilder1 = workPart.PropertiesManager.CreateMassPropertiesBuilder(objects2)
massPropertiesBuilder1.LoadPartialComponents = True
massPropertiesBuilder1.Accuracy = 0.99
massPropertiesBuilder1.UpdateOnSave = NXOpen.MassPropertiesBuilder.UpdateOptions.Yes
massPropertiesBuilder1.UpdateNow()
massPropertiesBuilder1.Destroy()
End Sub
End Module
Hope this helps!
NX8.0.3.4 TC 9.1.2.3.
HP Z820 / QuadroK4000
Bingo! That works (in a lot less than 139 lines). Thank you.
Here is an updated version of the NX Journal file so that it now assigns a mass to a body or multiple bodies in a part. It calculates the volume of all the bodies in the part, calculates a density and then assigns the density to all the bodies.
[pre]
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Imports NXOpen.UF
' Note: This is adapted from and
' the GTAC sample called: Report each body density with units.vb
Module NXJournal
Sub Main()
Dim dblVolume as Double = 0
Dim strVolumeUnits as String
lw.Open()
lw.WriteLine("Original Body Mass Properties:")
For Each aBody As Body In workPart.Bodies
iBodies(0) = aBody
lw.WriteLine(aBody.ToString() & ":")
lw.WriteLine("Volume = " & mb.Volume.ToString() & " " & massUnits(1).Abbreviation())
lw.WriteLine("Current Mass = " & mb.Mass.ToString() & " " & massUnits(2).Abbreviation())
dblVolume = dblVolume + mb.Volume
strVolumeUnits = massUnits(1).Abbreviation()
Next
lw.WriteLine("Total Volume of All Bodies = " & dblVolume.ToString() & " " & strVolumeUnits)
' Input the Mass
Try
MsgBox("Okay, be that way. Cancelled!", MsgBoxStyle.Information)
Return
End Try
lw.WriteLine(vbCrLf & "New Density:")
lw.WriteLine(dblDensity_kg_mm3.ToString() & " " & "kg/mm^3")
lw.WriteLine(dblDensity_g_cm3.ToString() & " " & "g/cm^3")
End If
Next
' Update Mass Data
' Adapted from ThorA Posting
' Dump out new mass
dblVolume = 0
lw.WriteLine(vbCrLf & "New Body Mass Properties:")
iBodies(0) = aBody
Next
End Sub
End Module
[/pre]
